RPM based manual HTTPS configuration
If you are changing your domain from HTTP to HTTPS, you will unlink the browser extension of all the users. Before changing the domain, you must ensure that all the users have a copy of their private key to recover their account.
Pro tips: In order to download their recovery kit, users can follow this dedicated guide
If you are reconfiguring passbolt you most likely want to say ‘NO’ to the mariadb or havaged setup questions and go for the nginx setup
MariaDB / Nginx / SSL settings
Passbolt PRO RPM package on come with a configuration helper tool to prepare MariaDB, Nginx and SSL settings.
You must prepare your SSL certificates before launching the tool. Be sure to write down the full path to your cert/key combo, as it will be needed in the nginx configuration process.
Please, notice that for security matters we highly recommend to setup SSL to serve passbolt.
Launch passbolt-configure tool and answer to the questions:
sudo /usr/local/bin/passbolt-configure
Nginx
Please enter the domain name under which passbolt will run.
This hostname will be used as server_name for nginx and as the domain name to register a SSL certificate with let’s encrypt if you don’t have your own SSL certificates.
Hostname: passbolt.domain.tld
SSL configuration
There are 3 choices available for SSL configuration:
- manual: Prompts for the path of user uploaded ssl certificates and set up nginx
- auto: Will issue a free SSL certificate with Let's Encrypt and set up nginx
- none: Do not setup HTTPS at all
Setting up SSL...
1) manual
2) auto
3) none
If you choose 1, you will be prompted for the full path of your certificates:
The certificate's private key should not be passphrase-protected so that the web server can read it.
Enter the path to the SSL certificate: /path/to/certs/cert.pem
Enter the path to the SSL privkey: /path/to/certs/key.pem
Nginx and MariaDB are now on the way to be configured. You will be notified at the end of the process to connect to the Passbolt web interface to finish the configuration.
Installation is almost complete. Please point your browser to
https://passbolt.domain.tld to complete the process
sudo systemctl reload nginx
Finally, ensure fullBaseUrl
value in /etc/passbolt/passbolt.php
starts with https://
